查看: 2410|回复: 4
蓝星星火推出新产品STARSIL® 线性体 Linear Polymer
宏道 发表于 2016-11-17 17:02:30 | 显示全部楼层 |阅读模式
概述
Description
STARSIL®线性体是一种低粘度直链羟基封端聚二甲基硅氧烷。
STARSIL® Linear Polymer 0325 is a low viscosity, linear, reactive silanol fluid.
应用
Applications
STARSIL®线性体可应用于:
STARSIL® Linear Polymer 0325 are used in the following applications:
● 线性体自身之间或与反应性烷氧基硅烷进行缩合反应;
Linear Polymer 0325could be reacted for condensation reaction with itself or with other organoalkoxysilane;
● 氨基硅油生产的原料。含有活泼的羟基,与氨乙基氨丙基三甲氧基硅烷,氨乙基氨丙基甲基二甲氧基硅烷等氨基硅烷反应缩合得到的氨基硅油,可更好的与织物表面 上的羟基产生定向吸附,使纤维间的摩擦系数显著下降,可以赋予各种织物良好的 柔软性及光滑性,并可改善其耐洗性;
Raw materials of amino fluid. Getting amino fluid through condensation reaction with[3-(2-Aminoethyl) amino propyl] trimethoxysilane, 3-(2-Aminoethylamino) propylmethyldimethoxysilane or other amino silane because of its reactive silanol group. It will gives excellent softner, lubrication and washability property to different textile for its better directional adsorption with the hydroxyl group of the fabric surface.
● 甲基乙烯基硅橡胶的结构化控制剂,也可以作为纸张防粘剂。
Process additive for Methyl vinyl cured silicone rubber, and also be used as paper anti- stick agent;
优点
Advantages
STARSIL® 线性体具有下列性能:
STARSIL® Linear Polymer 0325 have the following properties:
● 较好的粘度稳定性;
Good stability in viscosity;
● 基本无嗅;
Essential odorless;
● 耐臭氧,紫外线照射和高低温的极端温度。
Resistant to ozone, to ultraviolet radiation, and to ultra-high or ultra-low temperature.
特性
Characteristics
● 外观..........................................无色透明液体
Appearance......................Clear to slightly hazy liquid
● 粘度 (mm2/s),约.............................100~150
Viscosity at 25°C, mm2/s, approx............... 100~150
● 挥发份,约,%.............................................0.96
Volatiles, %, approx..............................................0.96
● 羟基含量,约,%.........................................1.02
Hydroxyl, %, %, approx........................................1.02
包装
Packaging
STARSIL® 线性体以 200kg 桶装或 1000kg IBC 桶装。
STARSIL® Linear Polymer 0325 is available in 190 kg drums or 1000kg containers.
储存与保存期限
Storage and shelf life
在+25°C以下条件下保存在原装密闭容器中,STARSIL® 线性体 的标准有效期是从生产日期起 18 个月(失效日期)。请参考包装上的储存建议和失效日期。
When stored in its original unopened package at a temperature lower than +25°C, STARSIL® Linear Polymer 0325 can be stored for up to 18 months from its date of manufacture (expiry date). Comply with the storage instructions and expiry date marked on the package.
- END -
kevinsun 发表于 2016-11-18 13:15:30 | 显示全部楼层
好东西,支持一下
TXHG 发表于 2016-11-19 15:29:22 | 显示全部楼层
:victory:
pengcun2007 发表于 2016-11-21 09:13:04 | 显示全部楼层
想请教下该款产品与市面上已有的低粘度107胶相比有什么特点呢?
云出无心123 发表于 2016-11-21 14:37:45 | 显示全部楼层
不知道和道康宁的40黏度的羟基硅油比有什么特别之处?
