查看: 1415|回复: 15
蓝星FLD 21600
TXHG 发表于 2016-10-24 10:16:45 | 显示全部楼层 |阅读模式
蓝星的FLD 21600是啥产品?谢谢!!!
kevinsun 发表于 2016-10-24 10:30:13 | 显示全部楼层
21600是蓝星的一只氨基硅油,主要作为纺织行业的柔软剂的原料
kevinsun 发表于 2016-10-24 10:32:00 | 显示全部楼层
BluesilTM FLD 21600
Technical Data Sheet  – August 2015
PERFORMANCE ADDITIVES
  Description BluesilTM FLD 21600 is an amino functionalized polydimethylsiloxane, specially developed for formulation to emulsions for textile softening. Characteristics Typical values, not specification properties. Appearance………………………………………clear to slight haze yellowing fluid Odor……………………………………………………………..slight odor Viscosity at 25℃, cp, approx……………………………….    6000 Ionicity………………………………………….. ……………     cationic Active content(%), approx………………………………………85%
Uses and applications
BluesilTM FLD 21600 is designed for use as a base fluid for formulation of amino silicone emulsions, specifically to be used as textile softeners. In application to textiles the product typically yields:  Silky, rich, bulky, soft handfeeling   Good hydrophilic  Low yellowing to finished fabric  Good acid and alkaline stability  Good shearing stability Typical end uses include cellulosic and man made fibres on woven, knitted and non woven fabric.
Formulation
Process
BluesilTM FLD 21600 is easy to be prepared into stable clear emulsion with less emulsifier. Following is the typical emulsification formulation. BluesilTM FLD 21600 ………………………………………  20% Acetic acid……………………………………………….. …  0.56% Alcohol tridencyl 6EO ………………………………………10% 1,2-propanol  ……………………………………………….. 3% Deionized water ……………………………………………..to 100%
1) Load BluesilTM FLD 21600, acetic acid, surfactants and 1,2-propanol, stir well. 2) Stir during 30 mins. 3)  Add slowly the water during approx. 1 hours with stirring 4)  Stir during 1 hour 5)  Filtration Packaging Plastics drums of 200kg on pallet of 800kg
硅胶新人 发表于 2016-10-24 11:11:26 | 显示全部楼层
:),学习了,,,谢谢
    ☆黑马☆ 发表于 2016-10-24 12:33:57 | 显示全部楼层
    BluesilTM FLD 21600
      {:soso__14347937040236606360_4:} 很不理解,中国人的产品要用外文写说明书!!至少在中国国内应该用中文!
    kevinsun 发表于 2016-10-24 14:16:34 | 显示全部楼层
    很不理解,中国人的产品要用外文写说明书!!至少在中国国内应该 ...
    黑马兄莫见怪,此产品确系国外生产的进口货,属于罗地亚的老产品了。:)
    云出无心123 发表于 2016-10-24 14:50:12 | 显示全部楼层
    对呀,它既然在国内销售,又是中国的公司,为什么不做中文的说明书,好尴尬:(
    kevinsun 发表于 2016-10-24 14:59:16 | 显示全部楼层
    因为罗地亚有机硅这块在07年都卖给蓝星了,所以现在称它为蓝星的产品。
    蓝星有机硅国际这块确实比较尴尬,虽然名义上说是国企,但是其实从里到外都还是外企的管理和运作。
    蓝星星火那边就是比较正宗的国企了。
    kevinsun 发表于 2016-10-24 15:03:27 | 显示全部楼层
    蓝星收购罗地亚有机硅的时候是把罗地亚全球的有机硅工厂和业务都一起收购了,像这个产品就是在西班牙工厂生产的,还有一些特种硅油和乳液是在法国工厂生产的。
     楼主| TXHG 发表于 2016-10-24 15:10:29 | 显示全部楼层
    谢谢,在哪找的说明书
     楼主| TXHG 发表于 2016-10-24 15:11:57 | 显示全部楼层
    就这样
     楼主| TXHG 发表于 2016-10-24 15:14:37 | 显示全部楼层
    在国内销售也得整点中文的资料,关键是就一代号,啥字都没有
     楼主| TXHG 发表于 2016-10-26 07:25:03 | 显示全部楼层
    根本不知道是啥东东,都准备扔一边去的
    硅胶新人 发表于 2016-10-26 09:08:18 | 显示全部楼层
    :lol:,吃下了,没法消化,土洋结合
