查看: 4325|回复: 24
有机硅新用途
caryfire 发表于 2014-12-3 14:55:32 | 显示全部楼层 |阅读模式
有机硅产品有很多的新用途,比如 防水纺织等等,希望有大神可以探讨下,指导下 。 有很多产品 需要我们去开发新的用途。
cspc 发表于 2014-12-3 18:28:04 | 显示全部楼层
With experience, expertise and innovation, Dow Corning delivers effective Oil & Gas solutions to help you control costs, increase reliability, maintain efficiency and reduce unplanned maintenance. No matter what your challenge, onshore, offshore or subsea – from exploration through drilling and resource extraction to pipeline transport and energy or petrochemical processing
回复 支持 1 反对 0
jssoopat 发表于 2014-12-3 16:04:13 | 显示全部楼层
LZ应该先谈一下自己的想法和看法啊
binggua131 发表于 2014-12-3 16:43:42 | 显示全部楼层
你是说硅胶布吗?
  • 签到天数: 3 天
    甘棠 发表于 2014-12-3 18:00:55 | 显示全部楼层
    硅胶布是指什么? 离型剂类的用途?
    cspc 发表于 2014-12-3 18:26:52 | 显示全部楼层
    这家伙是来找免费的知识的:lol:
    cspc 发表于 2014-12-3 18:29:21 | 显示全部楼层
    Silicone sealants help high performance buildings perform better and last longer, and make new design options possible. They enable amazing feats of architecture and the preservation of our most treasured landmarks – as well as making our homes more comfortable and energy efficient.
    Silicones in construction can:
    Solve structural glazing and weatherproofing challenges
    Contribute to energy efficiency in buildings
    Improve in-shop productivity and reduce material waste
    Extend building life and reduce life cycle costs
    Help realize sustainable development
    Achieve design freedom
    cspc 发表于 2014-12-3 18:30:12 | 显示全部楼层
    silicones help protect and aid in the lead-free assembly of LED-based lighting modules, thanks to their dielectric insulation, shock and vibration absorption, thermal stability, and optical clarity at elevated temperatures.
    cspc 发表于 2014-12-3 18:32:42 | 显示全部楼层
    we’ve used our expertise and green innovations in construction chemicals to help create durable, weather-resistant building materials and protective coatings. So when you build with Silicone, everything starts from the same foundation – a commitment to energy efficiency and sustainability.
    cspc 发表于 2014-12-3 18:34:48 | 显示全部楼层
    玩硅胶的小波波 发表于 2014-12-3 22:26:16 | 显示全部楼层
    “防水纺织”已经不是新用途了吧?好多年前就见到道康宁在卖涂到雨伞上的胶,两种,一种用防水图层,另一种是用于印花,难点就在两种加成型的硅胶相互粘接。一般来说,两种胶,道康宁的胶能互粘,国产胶与道康宁胶能互粘,国产胶不能互粘。
     楼主| caryfire 发表于 2014-12-4 09:36:00 | 显示全部楼层
    “防水纺织”已经不是新用途了吧?好多年前就见到道康宁在卖涂到雨伞上的胶,两种,一种用防水图层,另一种 ...
    我指的是,,建筑防水  、 纺织处理等  ····比如硅烷   五年前估计很少有人能想到能用在建筑防水上      有机硅改性 可以开拓新的用途。
     楼主| caryfire 发表于 2014-12-4 09:38:16 | 显示全部楼层
    这家伙是来找免费的知识的
    不是免费找知识····     是大家互相探讨   能发现新用途  对大家都有帮助吧,
    cspc 发表于 2014-12-4 13:35:15 | 显示全部楼层
    比较好的方式你把自己的经验和看法先说出来,不要假装greenie或以为别人会先告诉你,所谓的舍得的含义我想大家都知道。
     楼主| caryfire 发表于 2014-12-4 15:54:12 | 显示全部楼层
    比较好的方式你把自己的经验和看法先说出来,不要假装greenie或以为别人会先告诉你,所谓的舍得的含义我想 ...
    你是不是被人窃取过什么。。。。为何这种心态
